water in door was stuck on
Last year I had the ice and water continue to come out after releasing the actuator pad. I replaced the control board and all has been well for the year. Today I moved the switch to water and it would not shut off. I moved the switch to ice and the water quit coming. Do I have a board problem again or is there some other switch that would stick and cause this.
