water leak
Hi all, just bought a house with a Frigidaire pure-source fridge/freezer (model frs26lh5ds1). It wasn’t hooked up to water supply when I moved in, so when I did finally get around to it, I found the water inlet valve was busted. I repaired that (myself) and have no water leaking from the bottom of the refrigerator. My problem is now that the water leaks from the ice/water filter (that I also just replaced because it is unknown the last time it was done) inside the fridge.
Where do I go from here? I am not paying someone another $75 to tell me they can fix a water inlet valve for $225, when I did it myself for $60.
Sincerely,
first time homeowner with limited skills :wink: Sara,
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=frs26lh5ds1
Here is the operators manual, in case you do not have it.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240581300en.pdf
Take a look at the Control Parts section in the above parts.
Note that all parts for the filter assembly are not shown in the parts breakdown but are listed so also look at the listing. Depending where your leak is you may just need a new O-ring. Clicking on a parts picture or description will bring up more info.
