Water Leaking at Water Inlet Valve
I replaced the water inlet valve and it is leaking water where the lines connect to it.
All I can suggest is that you check the valve itself for cracks etc.
Also check your connections.
The following video may help.
Click on the picture for more info on the valve.
AP3192626
