water level switch failure and flooded floor
hi
my machine will not stop filling and floods( on both hot and cold fill )so I do not think its dirt in the fill solenoids. Full wide open fill volume not a dripping slow fill!
I’:confused: m thinking my fill level switch is bad? Can I use a meter on this and check as I raise and lower the air pressure on the switch diaphram with a hose to see if in fact this switch is failed and my root cause of the flood?!!
thanks
mike
