Water is not dispensing although it dispenses crushed and cubed ice just fine.
When in water dispensing mode and the switch is pressed, it activates the agitator inside the icemaker as if it is trying to dispense ice.
No water comes out but ice cubes accumulate in the chute because, as expected, the chute door is closed in water dispensing mode.
I suspect it is either the solenoid or the control board itself that’s causing the problem.
Any ideas? Thanks in advance for any tip or suggestion.
