Water not shutting off
Have an Amana refrig. Model# DRS2662AW and Serial# PDRS2662AWD
Last year replaced the water valve that feeds the ice maker.
Now the problem is the water dispenser in the door. Sometimes the switch or valve does not turn the water off right away after you remove your glass from the dispenser. So keeps running for a couple seconds.
What part do I need and cant see how to get to the part.
