I replaced the coupler last week on my sisters washer i think i moved the clear hose & maybe dont have it in the correct place the water will not shut off & over flows in the fill mode. help plz
If the clear hose is not attached to the tub, the water will never shut off. This hose attaches to the pressure switch to tell the water valves when to shut off water to the unit. You must attach the hose with the basket empty of water, or water will travel up the hose and damage the pressure switch.
