Water Overflows And Doesn't Stop On Fill Up
When The Water Is Filling Up, It Will Not Shut Off And Overflows On The Floor And Begins Agiatation. I Looked At All The Parts And Unsure What It Might Be?thanks In Advance!!! Michael
— Begin quote from GTA17;209147
try checking the pressure switch… make sure the tube from tank to the switch is not blocked or a restriction… if clear replace the pressure switch.
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch’s set point then the switch activates turning off the water and starting the agitate.
Possible problems.
  1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
  2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
  3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
    If you cannot stop it the switch is toast.
Note: I am assuming that you can stop the water flow by unplugging or turning off the unit.
If the only way to stop it is to shut off the taps your water valve is shot.
