water pump
How do you get at the water pump to replace it.
— Begin quote from magician59;298606
Please look again at the model number to confirm. I don’t find such a model.
Is it an "Atlantis"?
It is a Bravos and that is the model # I have a part # as1472275 or W10217134…thanks
You should be able to access the pump by removing the panel in the back of the washer. It will be located near the back, and to the left as you look into the access. A pair of pinch-off hose clamps or pliers will keep the water leakage at a minimum.
I will be replacing this water pump on my Whirlpool Cabrio (part# W10217134). I see how to remove the hoses and the 3 screws to remove it from the housing… my question is how does the electrical connect come off? Thanks in advance!
