Water running out from under GE refrigertor/freezer
I have water flowing out from under my GE refrigerator whenever I place a glass into my water dispenser. NO/Little water comes out the dispenser at this time. There is no water leakage at the solenoids or supply lines going up the back of the unit. How do I get to the water line inside the unit that feeds the water dispenser?:mad: The freezer and Ice Dispenser work fine.
Check the connection at the lower hinge of the freezer door. There should be a white/clear plastic union there. Will probably have to remove front toe grill to access it.
