water sometimes fills into bottom then leaks
Water sometimes fills into bottom when dishwasher is not being used then
leaks out lower left front of door. When away it flooded room and soaked carpet. Door seal looks OK. Cannot replicate problem. Fill/wash/drain cycle seems to work normally. Water inlet valve seems to work fine. Cannot detect any seepage when machine is off. Shouldn’t Overfill Protection Float prevent overfill and subsequent leakage? Puzzled. Next step?
