Water wont drain, water on the floor
[SIZE=2]Walked into the kitchen to find water on the floor (lots) and evidence that it was coming from the dishwasher. I stopped the dishwasher and opened it up . All the dishes were wet and everything looked ok but the tub was full of water. Closed it and listened all noises were ok while it sounded like it was washing then the washing noise stopped and a fairly audible hum started and continued for a minute or so before the washing sound began again. I clean everything up drained the tub and removed all foreign debris that I could and tried it again. Same thing but I stopped it before the water started leaking on the floor. I suspect a bad drain pump because of the humming sound which my wife confirmed is not a normal sound. [/SIZE]
[SIZE=2]What do you think, replace drain pump?[/SIZE]
My wife just purchased a brand new Whirlpool microwave oven and sent to me. When I connect it, light comes on inside the oven but the plate does not rotate and the oven does not heat.
Please, help.
