My ice maker won’t make ice so I just replaced water inlet valves and new ice maker unit. I am now having a problem with the water not shutting off. Could you please advise me, how to stop the water from running.
Thanks,
Mickey
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GD25DIXHT02
Disconnect power to the valves.
If the water stops then you have received a defective valve.
