Wax motor not working
My washer is leaving the clothes wet when finished, I noticed the door lock light was not on while operating, the wax motor for the door latch was not working, a voltage test indicated that 124 volts AC was at the wax motor while machine was in opporation. Installed new wax motor but did not correct problem.
Thanks,
bcanapp
Hi,
Take a look at the R-11 resistor on the control board to see if it’s burnt.
My range 1 yr 2 months old and gives a fault code of F10 when trying to use oven. It just past the 1 yr warranty
Gene,
The complete model # is 790.9421240A and the fault code is F10 Sears won’t send a repair man out unless it is Tuesday and someone needs to be here from 9 to 5 and with my schedule the range won’t be fixed till Xmas next year! I would appreciate any help you can give me.
Thanks Les Roderfeld
