When Door Opens, Buzzing & Flickering Lights
Our Whirlpool Gold Conquest Side by Side Fridge Freezer begins buzzing when the Fridge door is opened, the lights flicker and the LED for temp adjustment go on and off. The buzzing comes from under the fridge.
The buzzing stops if the door open switch is pressed, the bulbs are removed. With the bulbs out the fridge works seemingly fine.
Model # is GS6SHEXNS00. The electronic circuit board on this model is the back but have not checked wiht voltmenter, etc.
