Where can I buy bearings?
Where can I buy a tub bearing kit, or both bearings, shaft seal and tub seal? That is, without the tub half, I do not need the tub half.
I cannot find any info on the given model number.
Perhaps the following will help.
http://forum.appliancepartspros.com/washer-repair/57726-neptune-bearing-repair-pic-tutorial.html?highlight=tub+bearings
I found it by using Advanced Search / Search in Forums / Washer Repair / "tub bearings" perhaps there are other posts in this search that my help you.
— Begin quote from denman;783580
Thanks! I have already viewed them. I need somewhere to buy the parts without the tub half.
I know the seal kit is probably available from AppliancePartsPros.
The reason I say probably is that I cannot find any info on the given model number.
I even tried the Maytag site with no luck.
— Begin quote from denman;783749
Typo on the model # MAH 6700 AWW. AppliancePartsPro shows the back half of the tub cover available (I suppose with bearings, but no bearing kit)
Perhaps try calling the parts people.
The parts breakdown does not even show a seal kit which it does for other front load models.
test posting
I have had very good luck with this website providing me with repair parts. If what you need is not available from this website, I have used VBX Bearing in Ca. with good results. 800-928-4430:)
I bought the seal and other parts from applianceparts pro,
— Begin quote from tmcneil;784235
bearings-USA Bearings
