wont drain and has electronic buzzing sound when put on drain cycle knob area (setting area on right for wash spin etc.). Doesnt sound like plugged but some electronic controller is malfunctioning. Any ideas how to narrow down the problem and identify?
You need to open it up and check the pump and drain for obstruction.
I cannot get your model to come up, so if you need more info please check it and repost if the one you gave is not correct.
