We recently found what appear to be oil/grease stains on the clothing after washing them. The stains were not there when we put the clothing to wash. I can’t find any posts on the net of similar experiences. Does anyone know of any washer problems that would result in staining the washed items? Is there anyway that an oil leak somewhere on the washer could result in oil in the main tank. Thanks.
Pull the agitator off and the spin basket and check for a bad spin tube seal. You will need the special Whirlpool spanner wrench to take the drive block nut off the top of the basket.
Ge stove 20 months old. Electronic controlled stovetop and oven. Stovetop went dead and no power or response to stovetop. I replaced main motherboard but no change. I have 10 volts dc coming out of the main clock board going to each of the two boards, (right and left) that are behind the stovetop control buttons. There is a cluster ol low voltage wires goint to the right board from the left board and a tan/rose ribbon going to a board below the oven. I have not taken this board out, but there are some larger wires coming out of it indicating the 220 ac voltage supply to the heating elementsare supplied here. Where do I go from here? Steve
