whirlpool accubake range
Have error codes E2 F1. Turn off breaker and it will work for a while, then codes again. How do I check oven sensor and control board? Thanks
Yes it is, and you have to take the back off the oven, and unplug the molex plug, and then put your meter on ohms, and put the meter leads on each of the pins and get a reading. Tom http://www.applianceeducator.com
