I am replacing the machine control electronics assembly on my Whirlpool Cabrio dryer. I have disconnected all of the wires except for two that I cannot for the life of me figure out how to disengage. They are the violet and red wires leading into a tan clip (and connecting to the orange heater relay 2).
A photo is attached.
I’ve prodded, pulled, and squeezed, and they won’t budge. What am I missing?
Those are just spade terminals but I cannot tell if the plastic connector has a lock on it or not. If it does, it would be pretty visible. A flat screwdriver under the connector with a slight twist often times will get it loose with little effort.
