Washer won’t turn on. So far, I’ve unplugged it, checked the house fuse box, plugged it back in. Still won’t turn on. Last load I did was a few days ago and it became unbalanced. I fixed that and it finished normally. But now it won’t turn on.
Any ideas on how I can fix this?
Hi Laudry Queen
The first thing you want to do is to inspect and test the connections to the main board.
If they are ok, your problem can be the user interface or the main control. This service manual will show you how to test it, see Test 1
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Strange thing - it turned on and is working now. Not sure how long, though, so I’ll take a look at your link just in case.
