Whirlpool control board vs panel
Our Whirlpool Double Oven (Model GDB307PDB09) has been showing an error code of E6 F2 and from previous posts it appears the control panel or control board needs to be replaced. Is there some way to determine which needs to be replaced? And if it is the control board which part number is that - AP4701078? AP3598617? Or something else?
Also, is there a tech sheet available for this?
Thank you in advance for your advice!!
