Whirlpool Controls Don't Function
Can some one help me.
I can run dishwasher on Light Wash only. From last three days Normal, Heavy Wash and Pots & Pans don’t work. What could be the problem. Is it the fuse which is white with two connecting points and one end an one on the other or anything else that I can fix myself without calling a tech.
Any help will be appreciated
Its NOT the fuse if you have light wash!!! I would suspect that the TOUCH-PAD is bad.
Sorry I am just repeating the reply. Please ignore this message. My question is still the same.
Do I have to change the control panel?
I need to repace the coupler between the transmission and the motor. what is the procedure to take it apart
