Whirlpool dishwasher 1 1/2 years old no response from control panel
Dishwasher is recieving power but the Control panel went blank:confused: ,does not start no indicators light. Also it seems the dishwasher has some water in the tub from last run. I would appreciate any help. Thank you.
Your model number seems to be missing some digits at the end of it.
Most of the units have a thermal fuse on the control board that may have blown.
Also it is not uncommon for problems with the wire ni=uts that attach the unit to the house wiring.
FYI: you are in the wrong section of the forum. This is Oven Repair and you should have posted in the Dishwasher section.
I am sorry I didn’t realize I posted in wrong forum, can/should we move it to correct forum? After opening control panel It seems there is no Thermal fuse in this washer. I will recheck the wiring.
Might as well stay in this section.
http://www.appliancepartspros.com/parts-for-whirlpool-gu2300xtvq2.html
[COLOR="Red"]See the attachment for the tech sheet.
PS: It also shows a fuse
For some reason the site will not let me upload the tech sheet now. I will try again later today
[/COLOR]
Take a look at item 6 in the Control Panel Parts section.
It does show a fuse, click on it’s picture for more info on it.
AppliancePartsPros still will not me upload the tech sheet.
Perhaps it is too large.
So I have put it on a 3rd party site, see below
http://www.datafilehost.com/download-e142204d.html
— Begin quote from denman;781772
Download GU2300.pdf
Mr. Denman I really appreciate your help, I am not a technician, when I opened the control panel I didn’t see anything that looked like a thermal cutoff switch. This model doesn’t seem very common, there isn’t much on the internet when I do a search. I will look at the Pdf sheets you offered me. Again, Thank you for your help!
— Begin quote from StanF;781850
Mr. Denman I really appreciate your help, I am not a technician, when I opened the control panel I didn’t see anything that looked like a thermal cutoff switch. This model doesn’t seem very common, there isn’t much on the internet when I do a search. I will look at the Pdf sheets you offered me. Also, I will check to see what parts I will need from your link. Again, Thank you for your help!
