Whirlpool Dishwasher repair
I have replaced an electric control panel on this unit 2x in the past year. I need to know if there is a part I can order to replace the wiring/harness assembly that is located inside the door, runs from the base of the door to the control panel. The connection that feeds into the control panel (part ordered was #8564546) into the slot W-R is melted on the one side and this may be the cause of the panel shorting out.
The main wiring harness AP3178193
The other way to fix it is to cut off the bad wire terminal with burned part of the wire and install a new terminal.
  • The insulated terminals (pack of 15) AP3440459
Thanks Gene, don’t know where or how you found that wiring harness part, as I looked and couldn’t find it. I like your idea of just replacing the terminal, especially since I believe only the one wire is bad… could I just go to a Lowe’s or electric supplies store to purchase a single termninal? What about the housing this bad terminal is encased in, which is partially melted, does that need to be replaced as well, and where would I find such a casing do you think? Really appreciate your help! Thanks again, Greg
