Whirlpool Dishwasher Wont Drain
All of a sudden my dishwasher stopped draining. It goes through the cycle but standing water left in tub. I found the flapper broken and replaced it but same issue. I checked the hoses and I cleaned the sump completely. The drain pump works and I also checked it with an Ohm meter. Does the circulation motor have anything to do with draining? If it washes fine, could it still be bad? Anywhere else I should look? There is no disposal, and the sink drains fine.
Wingr8
