whirlpool dishwasher
my dishwasher will not start. the lights for which cycle you want lights up, the cancel button works, we have replaced the mother board and the fuse piece. the repairman stated that we now need the console panel which is on backorder from you. do you have any help that you could possible give us. it is less than 2 years old.
Here is a tech sheet for a DU945PWPQ2
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535431.pdf
It does have info on how to test the keypad.panel assembly.
