I have a Whirlpool Model GI5FSAXVY02 (French Door / freezer on bottom). A few months ago, I pulled out the ice tray to empty the ice. When I replaced the ice tray, the controls on the control panel for switching to cce and changing the fridge temperature up no longer work. When you press either of the control buttons, all the control lights dimmly light up on the control panel. All other controls work just fine.
In general, I can no longer switch to Ice, and I am stuck at 35 degrees because the buttons on the control panel no longer function.
Should i just replace the control board (part # W10162500) or do I also need to replace the Dispenser Keyboard (part # W10164138).
Thanks for the Help.
Jason
