[SIZE=3]Need to repair upper door latch but I swear the door is [/SIZE][SIZE=3]hermetically sealed. There are 3 screws on the inside door frame nearest the latches, but when they are removed nothing gives. I looked at the YouTube video on how to remove the choke cover, but this unit is not built the same. I thought I would post here before tearing into the thing and probably ruining the entire door. Thanks for any help you can give![/SIZE]
Related topics
Have part, need help with door | 2 | 1703 | October 7, 2009 | |
Help to Replace Latch on | 1 | 872 | April 16, 2011 | |
Replacing Door Latch | 1 | 834 | January 20, 2011 | |
Will I be able to fix my Microwave door? | 8 | 2844 | June 11, 2009 | |
Help Someone! Ahhhh.... | 0 | 885 | June 1, 2009 |
