The display in my 2.5 year-old double oven went blank. I can turn the lights and fans on but I cannot read anything in the screen (not even the clock). I tried resetting, cleaning connectors and any suggestion posted on the web.
My conclusion is that I will have to replace parts… My question is: should I replace the control panel (P/N 8302319) or the display component ( P/N 8300435)? or both? Is there any way to know for sure where is the problem?
Thank you
I ordered both parts just to be safe. Unfortunately I received the wrong display and the control panel, as you said, is backordered. As soon as I receive it and solve the problem I will post my results here. Hopefuly it will save you some $$ or time (if the control panel ever arrives)
Hi.
I have the same problem with our double oven.
What was your solution?
Thanks.
Dan
— Begin quote from jrgaytan;45421
What was the fix?
— Begin quote from oceanmann1;65314
Hi.
Thanks.
Dan
I have the same problem. Did you get it fixed?
I have the same problem and someone told me it might be the transformer.
