Whirlpool Dryer Drum Won't Work
The drum stopped turning, but there was still a buzzing sound when pushing the start button. The belt felt loose at the belt idler so I replaced the belt. The drum still wouldn’t turn. Tried turning the motor by hand & couldn’t do it. Had someone push the start button as I watched the motor, which only turned very slowly & erractically. Smelled something electrical burning & stopped.
Does the motor need replaced or could there be another problem?
Thxs
Sounds like the motor has gone bad.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=245321
