Now, however, I’m having trouble with the controls. Occasionally, the dryer won’t power on unless I play with the controls for a few minutes. Then in most of the cycles, the temperature setting will continually cycle through while the dryer is running as if the button is stuck down. I can occasionally get it to stop if I switch to a new cycle setting or unplug the dryer and start over - but definitely no clear connection between what I do and its behavior. Stumped as to what I can do to fix it. Was the new part bad?
