Our dryer is not heating up. It spins and blows cold air. My husband cleaned out all the duct work and it didn’t help. He changed the thermal fuse. That wasn’t it. Any ideas? It is a whirlpool dryer.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LER6636P
See the attachment for the wiring diagram.
If the replaced fuse was Item 19 in Section 1 then it is not the one for the heating coil. It kills power to the motor.
First thing to check is the power to the unit.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
If the power is good, check the heating coil.
If it is good check the thermostats and the thermal cut-off.
If the thermal cut-off is blown get back to us as you have to find the cause of it blowing.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
