Whirlpool dryer not heating up
Hello,
My dryer stopped heating up on the automatic cycle, but worked on the other two cycles. A week later none of the cycles heat up. Timer?
Thanks,
Mike
Hi.
Install the jumper wire at BK-R and try.
If the heat works - replace the timer 3976584
Check if the ignitor glows on/off.
Yes - replace the control coils.
If not - check the ignitor, thermal fuse, cycling thermostat, cut off thermal fuse, hi-limit.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840
Thank you. Post the results.
Simon.
