whirlpool dryer replacement motor297787
I am in need of assistance. I received my new dryer motor today. The wiring connection are very different from the original. The old motor has a switch 3388235 with each wire connected separate and not a plug end like the one that I received. Im sure there a way to change this over as to make this motor work…The new motor have the numbers imprinted on the plastic switch. I thought I had them all correct until I blew the thermal fuse. I switched what I thought may have been wrong and used a jumper wire to bypass the thermal fuse…now I get zero…Please help!!
Did this also mess up the new motor as well?
MODEL#11096284100
