I have a whirlpool dryer that will not start. It was working fine and then would not start.
I have checked the power source and it is good, the light insdie the drum works. I have checked the door switch and is it OK. The vent is clean.
I have removed the on/off switch and will try to get a new one tomorrow but now I am wondering if the problem could be the thermal fuse.
Is there an easy way to determine if the problem is the switch or the fuse or do I have to use a meter?
You really should get a meter, they are not expensive ($15.00 to $20.00 at a good hardware store, as little as $3.00 at the cheapo imported tools store).
However, if you want to test the thermal fuse without it you can do this.
- Unplug the dryer
- Take the leads off of the thermal fuse and tape them tightly together.
- Plug in the machine and see if it works.
If it operates ok, replace the thermal fuse.
NOTE: DO NOT UNDER ANY CIRCUMSTANCE FOR ANY REASON OPERATE THE MACHINE IN THIS MANNER. THIS FUSE IS ONE OF THE FEW THINGS STANDING BETWEEN YOU AND YOUR HOUSE BURNING DOWN!!
Ok?
