Our dryer will not start, though light inside works and timer ticks. There was a large lint build up at the last use. I took off the back panel and the fuse looks fine (just a black strip, nothing burned) and i cannot tell if the other thermostats are blown, as I do not know what to look for, and they do not look to be resettable. I am not sure what to do/replace/test. Any help would be appreciated
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GEQ8858EQ0
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406699.pdf
You cannot tell if the fuse is blown just by looking at it. Note it is Item 7 is Section 3.
AP3132867
Unplug the unit and remove one wire from it and check it with a meter, should be 0 ohms.
Jiggery pokery method is:
Unplug the unit.
Remove both wires from the fuse and short them together.
Tape them so they cannot short to anything else.
Plug it in and give it a try,
If blown replace it ASAP as it is a critical safety device.
Prevents lint fires which can turn into house fires.
Be sure to clean the blower wheel and clean/check your vent system as this is the most common causes of it blowing.
yep that did it - its the fuse - thanks a million
