Dryer turns on and off fine…at on position it turns just fine…no heat…any suggestions? Thanks in advance…
Here is the parts breakdown.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LER5620KQ1
First thing to check is power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next would be the heater itself. Should be around 10 to 12 ohms.
Next would be the thermal cut-off (Item 9 in Section 3).
If it is blown get back to us as there are other things you should check before replacing it.
