Whirlpool Dryer
My dryer stopped working for no apparent reason.I have power to it and have run continuity tests.I am unable to figure out why it won’t start.Please help.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED5840SW0
Need more info.
How do you know you have power to it?
What is the L1 to Neutral voltage?
You ran continuity checks.
What/how did you check and what readings did you get?
When it does not start does it make any noise at all or is it totally dead?
In timed dry mid cycle does the timer advance?
