Whirlpool DU810SWKU0 dishwasher won't wash
Hello,
My dishwasher will fill with water but instead of water spraying around inside, it will just hum. Can someone help me with what could be wrong and if I will need a new part(s)? It’s about 5 yrs. old and hasn’t been used too often.
Thanks!
Can you check underneath for any kids of water leakage around the pump & motor?
Nat
Most likely it is a stuck seal. They make a seal kit for these. On ge brand dishwashers when this happens, we just turn the motor till it breaks free, and it will work just fine, not to sure if it’s the same for your washer.
