My Whirpool Duet is JUST 2 years old. I opened the dryer after a load and the light bulb popped. Now the dryer won’t start at all, I can turn on the power and select the setting, but when I try to start it it jsut beeps at me. HELP!
We had the same problem.
HOW IT WORKS: When the dryer door opens/closes it pushes or releases a little knob inside the door (on ours it is in the top left position). When it is released the light inside comes on and the dryer will not start, will show panel lights but will beep if you try to start it. When it is pressed (when the door is closed), the light turns off and it will let you turn the dryer on.
Being that the knob was not working properly, there was no communication when the door was opened/closed to tell it to turn on the light or let the dryer start.
SOLUTION: Purchase a new knob, part number 8519323 (also part number 8283288). This comes with both the knob and the wiring, but we only had to replace the knob itself.
REPLACING KNOB: It is easily removed from the outside.
- Open dryer door.
- Press (squeeze) the left/right sides of the knob and pull it out.
- Put in the new knob and press into place.
It was as easy as this for us anyway. The part was approximately $38.
OK, will the switch cause the bulb not to light? I changed out the bulb and figured it would at least light up even if the switch was bad.
It can be a bad switch. You have to check it for continuity.
thank you for the quick response. So the switch will cause the light to not light up?
I have a new bulb in it and it still won’t light with the door open. I can go down in the morning and buy a new switch but I really want to make sure I am getting the right thing.
As I said earlier - do not rush with the part. Check the old switch for continuity first.
What is the complete model number of the washer?
Yes, the light will not work if the switch is out (at least that’s what happened with our dryer). The signal is not getting through to the light bulb to tell it whether the door is open or closed (thus telling it to turn on/off), the same concept applying to whether the dryer will start or not start, the message is not getting through the switch.
Both of these problems were resolved when we replaced the switch (see my detailed description above of our problem and solution).
Best to You!
— Begin quote from danpomeroy;68459
Sweeeeeeeeeeet! Happy to help. Now, have fun doing all of the laundry that has piled up in the last few days.
— Begin quote from danpomeroy;69379
That worked great!!
Thanks for all the help.
I just had the same problem happen to my 2 1/2 year old Duet Dryer. The light blew into shards and then the dryer wouldn’t work. The diagnostics pointed to the door switch because there was no beep when the door was opened in diagnostic mode. I plan to replace the switch but this seems to be a more common problem, should it warrant a recall?
Seems like a common occurance. Whirlpool needs to step up and install a heavier duty door switch. It should be able to handle a light bulb burning out. I haven’t replaced the bulb since my door switch fried.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gsd5134do1ww
Glasses ect. placed in upper basket are not cleaning. lower wash arm tower is about 4 inches below upper wash arm when fully extended. Should tower contact upper wash arm in order to function properly?
Not sure about this. Pull the lower tower up by hand and that should tell you where it should be when fullu extended.
Any other suggestions for solution to problem?
Check that the holes in the tower are clean.
Check that the holes in the upper arm are clean.
Remove the sump cover (inside tub center) and check for debris or something wrapped around the chopper. Be careful there is often broken glass in the sump.
Also could be a low water problem, though usually you will hear this re: the unit growls. Most units fill to just under the heater.
You could try adding some water to the unit during a fill just do not overfill it.
If the unit now runs OK that is your problem.
The most likely cause is a partially plugged screen filter on the input side of the water valve. Remove the valve from the unit and clean it. Do not permanently remove the filter from the valve, it is there to keep crud out of the valve, which could hold it open and cause a flood.
After my lamp failed (without causing any damage) I decided to check if there was a way to replace it with the new style LED lights like the new high end refridgerators and other appliances are increasingly showing up with.
Since I have worked in electronics for over 15 years and am pretty familiar with using LED lighting in various systems I support, I figured this would be a relatively easy thing to do. And it turns out it is.
The standard filament lamp that appears to fail by destroying the door switch in many cases is a standard E12 120V 10W lamp. It can be found in many appliance repair depots for around $12, but if you know what it is, you can easily find it everywhere else for about $1.60, it is better known as a Candelabra E12 lamp.
So the first stop in my quest is where I have found many of my LED lamps, superbrightleds.com. They happen to have the E12-W21, 120V 2W LED lamp that is about the same size and shape as the existing one in my Duet dryer. It is about 50 lumen and is available in two colors, Cool White which is kind of light daylight, slightly Blue in color, and Warm White, which is like a filament lamp, somewhat Yellow in color. Either one will work, but due to the nature of LED’s the Cool White one is slightly brighter.
So I ordered one for about $15 + s/h and installed it. It was a simple plug and play installation, just remove the plastic shield, remove the old lamp, screw this one in and replace the shield. I recommend unplugging the dryer first just in case the other one is cracked and sometimes old lamps will flash when they are unscrewed since the broken filament will start making intermittent contact. This is even more critical of course when the lamp explodes and the remains are still energized when you open the dryer door.
The new lamp is comfortably bright, and the 21 surface mounted LED’s all light up at once, making it easy to see things as you remove your laundry and hunt for stray socks and other things dryers tend to hide.
The bonus will be no more door switches damaged, the LED’s are rated for tens of thousands of hours so the new lamp will last the lifetime of your dryer and several dryers after that.
Some minor disclaimer on this. LED lamps are sensitive to heat. This particular LED lamp is rated to operate up to 113 degrees fahrenheit. The site probably frowns upon it being used in an appliance and won’t warranty it if it fails, so this installation would be entirely done on your own risk.
I did however install this lamp over a year ago, and it has worked flawlessly ever since. I have no reason to believe it won’t do so in 99.99% of cases.
Hope it helps and best of luck…
