Can Someone Tell Me How To Replace This Part On My Dryer? How Do I Get The Old Part Off To Replace It? Thank You
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED9200SQ0
I am not sure what parts you are referring to.
If you click on the part’s picture or description a new page will open with additional info on that part, perhaps it will have the info you need.
Did you ever find out how to fix the trim? I have a similar problem…I’m just trying to get the clips reattached the trim so we can use the dryer again because it won’t work without the trim firmly in place.
