Whirlpool Electric Range Dual Burner Issue
The LF dual burner is hot regardless of the temperature setting. It was initially noticed when using the dual burner but seems to have the same issue when using the single burner. On a similar thread I found that the pro recommended that the infinite switch was the possible culprit. Could this be true in my case?
