I get a F71 error code. I have jiggled the wiring harness connections, unplugged the unit etc. The code will disappear, but it will reappear after 10-12 hours.
Inside the lower service panel should be some tech notes, but its sounds like the problem is with the control unit. If you can live with the problem for a while it might fix itself.
