Our dryer spins fine and even begins to heat up at the beginning of a cycle, but then the gas/flames cut out after about 10 minutes max. Once the gas cuts out, I have to wait at least 30 minutes for it to "cool" before it will start up with heat again. If I don’t wait that long, it just spins with no heat. The times it does this I can see the flames start up (orange glow) but then they do not catch (orange glow goes away).
I have read a couple posts with similar issues and while I have not gone through the entire continuity test (tracking down my meter), I do believe that the thermal fuse is fine through a taped wire test. Hopefully I can run through the full test tomorrow, but any thoughts in the mean time would be great.
