The coils are on top of the regulator. You can see them on the break down of your dryer.
Hope that helps.
Gene was more help than I was. Glad he jumped in!
Nat
Kathy,
I found a simple solution to your problem. I worked for me. Remove the float assembly (top Portion). It comes out very easily. Take a short piece of tubing (from any lowes or home depot) that will slip over the plunger of the float after the tubing is split down the middle. This tubing has to be split to fit over the bottom of the plunger and still be small enough to allow the slide to go up and down on the holder that is part of the assembly that is attached to the bottom of the inside of the DW tub. You will need to only use a length of the tubing that is long enough to ride inside of the assembly.
That the dishwasher is level or slightly tilted to the back.
That the wash arm holes are clear. Sometimes they can get a partial plug and it will spray water out at a weird angle and cause a leak. I find it best to remove junk from the holes when it is wet using a pair of tweezers.
