I have a Whirlpool SF379LEKS gas oven that recently stopped heating, and I am out of ideas on how to repair it. The stovetop and broiler both work fine. The oven, however, would not light. The spark electrode would click four times then stop and never try again, even though the control panel said it was still preheating. I replaced the oven burner/ignitor assembly and now it clicks once and lights, but will not warm up to temperature. You can feel a little warmth in the oven after the 10 minute preheat to 350F, but that’s it. I replaced the control panel with a refurbished one and the flame sensor with an aftermarket one from Amazon, and neither one fixed the problem, wondering if they aren’t working right. Would appreciate any suggestions, thanks.
Related topics
Gas Oven won't stay lit | 12 | 55131 | January 17, 2011 | |
Oven doesn't seem to get hot enough. | 1 | 947 | November 10, 2013 | |
Gas oven fails to heat up. | 1 | 605 | April 13, 2015 | |
Whirlpool gas range/oven doesn't ignite consistently | 0 | 2402 | August 19, 2009 | |
Whirlpool Gas Range Issue | 1 | 982 | December 31, 2011 |
