Whirlpool GEW9200LW0 clicks and senses, but nothing more
My dryer makes a clicking sound and the front panel lights up as it should, but the sensing light stays on and it just stops. It will not turn or dry at all. I have tried to enter test mode to get an error code, but get no response to the routine that is supposed to let me into test mode. Please help.
Frnak
Perform the Test# 4 (step 4) as instructed in the Tech sheet. Post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265488
— Begin quote from frnak;270700
Thanks Gene. I was wrong. I got into the diagnostic mode and it passed all tests with giving any error code. Should I try to do the technician stuff in later tests? I will need to borrow the ohm meter or whatever it is to get this done.
Yes, it should be the next step you’ll do. Follow the instructions from the Tech sheet.
— Begin quote from Gene;271261
I have tried step 4 and the ohm meter shows infinity at p2 on the control board. I took the toe panel off and am trying to test the resistance on the cables, but I CANNOT disconnect the sensor from the wire harness to test it. I have used pliers and tried to the pull them apart. What is the trick?
According to the instructions, if the result of the test was infinity, you have to measure the resistance between pins 1 and 2 of the connector P2 on the machine control board. You don’t have to go to the wire harness and the moister sensor.
In such situation I believe the problem is a bad machine control electronics.
