Whirlpool Gold Dbl Oven
Built in Whirlpool dbl oven inoperable since doing the self cleaning option. Was told by tech I need a new/rebuilt sister board. Just called your hotline and was told possibly need a thermal fuse as well as check the fan. Could you tell me how to remove the sister board as well as how do I test the thermal fuse and fan? Thank you.
— Begin quote from whirl1pool;666723
I did not call the hotline as the person above. I do know there is power since the lights come on when the door opens. The panel is completely out. Black, no error messages.
How do I remove the panel?
How do I get a new one?
What about the thermal fuse & fan?
I did just run the cleaning option on the top of 2 ovens.
Thank you,
John
