Please help…The time on my display is very dim. The oven will come on (both) but you can not see the temp or anything. The dim time (correct) remains on display at all times. What do I need to do to correct this problem. Can not tell the temp in the ovens.
The dim display problem has become a lot more common the last 10 years or so. I think its weak components in the display voltage circuit, but I don’t really know for sure if that is the problem on all of them.
You have three possibilities:
Replace the control board/display.
Have your display rebuilt. (there are places that can repair them now)
Buy a different Range/oven.
Here is the part number just in case you need it. WPW10438751
http://www.appliancepartspros.com/whirlpool-cntrl-elec-wpw10438751-ap6021414.html
If you need a repair service, just do a search. I’ve never used one, so I don’t know which ones are the best.
